Sweat the assets using SSE
Hi pack! (I couldn't resist ...
Time for another tutorial. This one is about how to cut down CPU using SSE in Flowstone. Some of the contents has been communicated before, some other may be commonsense, but maybe there is something new to discover? Find out and let me know!
Live long and prosper
MV
MV
UsingSSE.fsm- (53.61 KiB) Downloaded 1937 times
Re: Sweat the assets using SSE
Hi Martin,
i really appreciate your work here...
I only have the Slow Packs and slow Add Streams in my Toolbox => so the power Packs jumped right in it
Keep on doing!
Walter
Keep on doing!
Walter
Excellent resource Martin.
Many thanks for taking the time to make that for us
Hi Martin, This is just what I needed! ...
Thank you that did it for us !, everything works fine!
DigiTonix - Posts: 137
Thank you Martin!))
- anjey_olaf
Thanks Martin,
Some excellent examples and tools. I/we have learned a lot from you!
Cheers, BobF.....
Cheers, BobF.....
- BobF
I use them so many time, thanks !)
Here's a little add-on i like to use when using SSE in series.
This way one module will replace the in and out packers.
I made mono packs for 4x to 16x and stereo to 2x to 8x. With different output.
(It's also possible to include all of this inside one code..
But it could lead sometime to confusion, and slowing testing new code,...
i made them after breaking my head with some complex all-pass,
requiring to use SSE mix inside SSE mix, inside others bugs possibility inception ... ...)
SSE in series.fsm- (184.03 KiB) Downloaded 780 times
- Tepeix
Hum ...
Just after i made all of those module, i discover that it's more smart to use the first one,
and to place simply the code in series like this :
- Series more smart.png (36.14 KiB) Viewed 18101 times
- Tepeix
martinvicanek wrote:how to cut down CPU using SSE in Flowstone
Awesome tutorial.....thanks Martin...
