Sweat the assets using SSE
Postby martinvicanek » Sun Jan 22, 2017 7:11 pm
Hi pack! (I couldn't resist ... :oops: )
Time for another tutorial. This one is about how to cut down CPU using SSE in Flowstone. Some of the contents has been communicated before, some other may be commonsense, but maybe there is something new to discover? Find out and let me know!
Live long and prosper
MV
UsingSSE.fsm
(53.61 KiB) Downloaded 1800 times
Re: Sweat the assets using SSE
Postby Walter Sommerfeld » Sun Jan 22, 2017 8:21 pm
Hi Martin,
i really appreciate your work here...
I only have the Slow Packs and slow Add Streams in my Toolbox => so the power Packs jumped right in it ;-)
Keep on doing!
Walter
Walter Sommerfeld
Postby Spogg » Mon Jan 23, 2017 9:56 am
Excellent resource Martin.
Many thanks for taking the time to make that for us :D
Postby DigiTonix » Mon Jan 23, 2017 10:25 am
Hi Martin, This is just what I needed! ... :)
Thank you that did it for us !, everything works fine!
DigiTonix
Postby anjey_olaf » Mon Jan 23, 2017 12:01 pm
Thank you Martin!)) ;)
anjey_olaf
Postby BobF » Wed Jan 25, 2017 12:14 am
Thanks Martin,
Some excellent examples and tools. I/we have learned a lot from you!
Cheers, BobF.....
BobF
Postby Tepeix » Thu Jun 30, 2022 2:48 pm
I use them so many time, thanks !)
Here's a little add-on i like to use when using SSE in series.
This way one module will replace the in and out packers.
I made mono packs for 4x to 16x and stereo to 2x to 8x. With different output.
(It's also possible to include all of this inside one code..
But it could lead sometime to confusion, and slowing testing new code,...
i made them after breaking my head with some complex all-pass,
requiring to use SSE mix inside SSE mix, inside others bugs possibility inception ... ...)
SSE in series.fsm
(184.03 KiB) Downloaded 617 times
Tepeix
Postby Tepeix » Thu Jun 30, 2022 3:09 pm
Hum ... :oops:
Just after i made all of those module, i discover that it's more smart to use the first one,
and to place simply the code in series like this :
Series more smart.png (36.14 KiB) Viewed 13877 times
Tepeix
Postby billv » Sat Jul 23, 2022 9:28 pm
martinvicanek wrote:how to cut down CPU using SSE in Flowstone
Awesome tutorial.....thanks Martin... :D
billv
Return to DSP
