Midi Program Change Vsti that generates numbers.
Postby readyforCHRIST81 » Mon Apr 24, 2023 10:37 pm
I Need a Midi program change vst that generates numbers for Lsb, Msb and Program change
Channel Number 1 -16
Program Change (1 - 127)
Msb (1 - 127)
Lsb (1 - 127)
Generate button
Also generate numbers in between two numbers
( From 5 to 25, ex)
. Please to the coders... I'll donate been looking for this for the past decades trying to use for a daw to control Hardware Synth.
readyforCHRIST81
Re: Midi Program Change Vsti that generates numbers.
Postby Tepeix » Wed Apr 26, 2023 3:49 pm
But did you try to send 2 CC for Lsb Msb or a sysex message ?
(Don't know so much on the subject..)
Tepeix
Postby readyforCHRIST81 » Thu Apr 27, 2023 12:22 am
Tepeix wrote:But did you try to send 2 CC for Lsb Msb or a sysex message ?
Well i don't know too much as well. I know their are alot of professionals on here. That would be a blessing if some one can create it. If i was a programmer i would make also sorts of programs and gadgets.
readyforCHRIST81
Return to DSP
