Focusrite liquid mix to controller
Hi ! I own this firewire dsp prosseror called liquidmix 16 - although I like it a lot as already programed I wish to know if there is any way to map the knobs to flowstone for any further usage over midi mainly.
+ (irelevant)Also I'd like to make one of the knobs controll my system volume aswell (win7/64) is that possible also ?
My experience is mostly in max msp, but I've been using flowstone some time now aswell...
I hope you can help out !
- + (irelevant)Also I'd like to make one of the knobs controll my system volume aswell (win7/64) is that possible also ?
Wishx - Posts: 68
Re: Focusrite liquid mix to controller
if the controller is recognized as a midi interface, you can do it via ruby and winapi.
- Tronic
It is not recognized as midi :/ Its fairly autonomous in its own right and runs its own software, wet I still believe it can be done...
Wishx - Posts: 68
I do not know if simple thing, but you have to communicate with the low-level driver,
and without knowing the specifics it is a bit difficult.
- Tronic
What do you kneed to know for this ?, i might be able to provide you any info
Wishx - Posts: 68
Hi Wishx,
search for 'Midi learn' in this helpful forum!
Greetings 2 spain
Walter
Greetings 2 spain
Walter
