VST Plugin // Copying insert to another insert
I noticed that even if parameters are automatable that when you copy an insert into another insert slot, all the settings for all parameters in the plugin resort back to default (like at plugin initialization). Any ideas on how to make this work more like waves plugins... which preserves the exact same settings for the copied instance.
Edit: I also noticed that my plugin's settings revert back to default when re-opening a mix.
Edit 2: I've discovered that having your controls (if you're using knob primitives for example) set to both "Auto" and "Preset" allows them to function like you would expect.
- joeyismusic
Re: VST Plugin // Copying insert to another insert
put a preset manager in, usually thats whats missing that resets the parameters
Wishx - Posts: 68
