Pith Bend and Modulation
hello friends,
I need to know if anyone knows how to create or make my synthesizer recognizes the Pith Bend and Modulation MIDI input.
- Merigusapo
Re: Pith Bend and Modulation
Is that in a particular host?
I have had a bit of trouble with the FL studio version as it seems that it doesn't send midi pitchbend by default and instead seems to modulate the actual frequency value.
may be some fix for that but I just remapped the wheel on my keyboard to my own parameter enabled knob through the host.
There should be a module called 'midi pitch bend' if you search the toolbox, did you try connecting that to a float to see if it was changing value?
- dentistguba
