How to disable sound in Demo mode - export
Hello
Im making plug-in and Demo (i can make some restrictions like noise etc) but Do you have any idea how to disable sound in exprted wav file?
Many commercial plug-ins have this feature, in daw you hear sound but when you export wav file there is just silence.
Im making kick drum plugin so people can easily export wavs and use them as samples that is why noise restriction is not enough
Thanks
Thanks
- mayo
Re: How to disable sound in Demo mode - export
mayo wrote:Hello
Thanks
only one ideaI had is to add module EdOpen- Editor module opened but problem is that when you close editor window sound is turned off too and it may be curious for some people,
but some companies managed it and disabled sound in exported wav while sound is always playing when vst is used /opened or closed editor window doesnt matter/
- mayo
Last edited by MichaelBenjamin on Mon Sep 21, 2020 10:40 am, edited 1 time in total.
- MichaelBenjamin
Search for "offline" in the toolbox - you should find a primitive called "Offline Mode" which outputs true when the host is doing a rendering. I'd advise a little testing with it first to make sure it does what you want, though - I'm not sure if there are any other VST host conditions which make it output true, and there may be VST hosts which don't support it.
trogluddite wrote:Search for "offline" in the toolbox - you should find a primitive called "Offline Mode" which outputs true when the host is doing a rendering. I'd advise a little testing with it first to make sure it does what you want, though - I'm not sure if there are any other VST host conditions which make it output true, and there may be VST hosts which don't support it.
Thank you very much for idea, unfortunatelly it does not work in FL Studio, in Cubase works fine but not in FL
I dont know why because some other companies did it (muted audio when exporting from FL)
- mayo
Users browsing this forum: No registered users and 58 guests
