Visualizing input stream
Hi, I have a problem viewing audio coming from my mic. I've checked the asio settings and all is good.
I'm using the intergrated mic on my laptop. could someone tell me where i'm going wrong. here's a screen shot
thanks
https://skydrive.live.com/redir?resid=F ... phd5JpBfGM
thanks
- jto1
Re: Visualizing input stream
Dont' know for sure, but i will put an ASIO out , making sure is active. Usually "Blue" flow only works when an audio output is active
Free your memory, .. with a free(). Like a pointer
Cast a pointer into an integer and it becomes the integer...
Cast a pointer into a struct and it becomes the struct...
A pointer can overflow... or can crash...
Be a pointer my friend
- unkargherth
Ok cheers, i'll give it go.
- jto1
Brilliant! thanks unkargherth it works now
- jto1
