Issues with Armcontrol and Crustcrawler
I've seen another old thread with a similar issue, but the advice there hasn't helped me.
As far as I know, I've set up everything correctly. I'm running a Crustcrawler AX-18A arm with a USB2Dynamixel controller. My plan has been to program the robot using the Armcontrol software, but I can't make my arm move with it. The Crustcrawler sample program that has sliders to test the arm makes the joints move, and all the servos have the correct ID's.
When I open Armcontrol, I can choose the type of arm, and it knows which port I'm using, but the light with the port label does not turn on. Whenever I try to move the onscreen arms, nothing happens to my robot.
I've gone over the instructions repeatedly, unplugged and replugged my components, tested the servos with the slider program, but I can't figure out how to fix it. Any help would be greatly appreciated.
- boyd
Re: Issues with Armcontrol and Crustcrawler
Hi, did you ever solve the issue?
- edwardotis
