Send Data to Arduino
Discuss Control Systems here
Postby ivanncam » Sun Jun 29, 2014 7:54 pm
Hello, Im victor
I need help, I'm trying to send an array of data of a xbox controller but I don't know how to do it
The array contains just floats
I will use this to control some motors using PWM in arduino
In flowstone, I have use the Xbox360 Block and then a Ruby box to make the Array.
then I know I have to send the array to the Com Port block. This is the problem! I don't know how to do it
Is posible to send an Array like I want?
Is there another way to do this?
This is the proyect.
Can you help me?
controller (recovered).fsm
I need help
(36.6 KiB) Downloaded 3419 times
ivanncam
Re: Send Data to Arduino
Postby JB_AU » Thu Jul 17, 2014 3:11 pm
Floats are big numbers, i couldn't see the sense in over complicating with ruby, that's just me.
If you look up flowbluino on arduino.cc there is a pdf that documents some of these things, to make things easier.
controller (ruby free).fsm
(36.52 KiB) Downloaded 3442 times
Albert Einstein
JB_AU
Return to Machine Control
