Send Data to Arduino
Hello, Im victor
I need help, I'm trying to send an array of data of a xbox controller but I don't know how to do it
The array contains just floats
I will use this to control some motors using PWM in arduino
In flowstone, I have use the Xbox360 Block and then a Ruby box to make the Array.
then I know I have to send the array to the Com Port block. This is the problem! I don't know how to do it
Is posible to send an Array like I want?
Is there another way to do this?
This is the proyect.
Can you help me?
Can you help me?
controller (recovered).fsm- I need help
- (36.6 KiB) Downloaded 3482 times
- ivanncam
Re: Send Data to Arduino
Floats are big numbers, i couldn't see the sense in over complicating with ruby, that's just me.
If you look up flowbluino on arduino.cc there is a pdf that documents some of these things, to make things easier.
controller (ruby free).fsm- (36.52 KiB) Downloaded 3495 times
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
