VSTi Example Synth
VSTi Example Synth
Postby admin » Sat Dec 15, 2012 10:10 pm
Here's an example Synthesizer that can be run in real-time inside FlowStone or made into a VSTi virtual instrument plugin.
This Synth can be played via a MIDI keyboard or from the PC keyboard.
Example Synth clip.png (65.78 KiB) Viewed 73720 times
This example also uses some Ruby code to create a time accurate programmable arpeggiator that also follows the beat inside a VST host.
For completeness we have used an ASIO audio output module to reduce the latency. If you don't have an ASIO sound card then you can switch this module for a Direct Sound output.
Example Synth.fsm
(90.4 KiB) Downloaded 8393 times
admin
Site Admin
Return to Synths
cron
