Knob ratio : Compressor
Postby rustyou » Sun Jan 19, 2014 6:18 pm
Hello !
I have a question,
what is a value of knob ratio (0 - 1) of output : 1:1 ....etc
Exemple knob position 0 = 1:1
knob position (max) 1 = 8:1
How see the reference ??
Thank you
rustyou
Re: Knob ratio : Compressor
Postby Perfect Human Interface » Sun Jan 19, 2014 11:34 pm
Hello, I'm not sure exactly what you're asking for, but I added an output to my knobs for the 0-1 ratio as well as the set min/max ratio. Maybe something like that will help you? Or you could just set the knob to 0-1 and then multiply by 7 and add 1 outside of the knob.
Postby rustyou » Mon Jan 20, 2014 9:05 pm
Hi !
Ex :
How to define three position for my knob :
1:1
2:1
4:1
For this exemple, what is the value for my knob.
limit knob : 0min and max 1
Thx u
rustyou
Postby tester » Mon Jan 20, 2014 9:26 pm
Knob outputs just values, whether these represent ratios or something/anything else. You just set the min/max from 1 to N, and you have ratios, for example from 1:1 to N:1.
If you wish to have specific numbers - you can use a selector driven by knob out or if-then-else routine or some sort of down/up rescaling with integers, if this is supposed to be infinite range of regularly defined ratios.
ratio2.fsm
(125.44 KiB) Downloaded 916 times
ratio.fsm
(125.37 KiB) Downloaded 880 times
tester
Postby rustyou » Mon Jan 20, 2014 9:40 pm
Thank
In out meter monitor.
My compressor will be of knob = 5 --------> out monitor compress = 5:1 value ? exactly ?
Exemple ratio.fsm
Exemple
(13.49 KiB) Downloaded 870 times
rustyou
Postby tester » Tue Jan 21, 2014 1:52 am
Now, connecting second wire to your compressor - remember to scale your green value (on that second wire) appropriately to input requirements of your compressor part, to fit proper ranges there.
tester
Postby rustyou » Thu Jan 23, 2014 7:14 pm
Eh ...
For this exemple of compressor.
The value of ratio is : min =0 max=1
What the real value in output (1:1, 2:1...etc)
0 = 1:1
0.5= ?
1=?...
Thank you,
Comp.fsm
(190.88 KiB) Downloaded 909 times
rustyou
