Is there any envelope analyzer made?
Postby djbrynte » Thu Mar 06, 2014 4:49 pm
I mean an analyzer there you can see the signal of the envelope.
Like this.
http://howtomakeelectronicmusic.com/wp- ... roller.jpg
I mean there you can see how its drawed.
djbrynte
Re: Is there any envelope analyzer made?
Postby Xtinct » Thu Mar 06, 2014 6:35 pm
The multistage envelope has graphic interface or try here
http://synthmaker.co.uk/forum/viewtopic ... dsr#p87479
though the forum is a bit hit and miss loading at the moment.
Xtinct
Postby Nubeat7 » Thu Mar 06, 2014 8:19 pm
i did an adsr in ruby which can be setted with the mouse..
viewtopic.php?f=3&t=1756
Postby nix » Thu Mar 06, 2014 9:47 pm
I've got an envelope analyser somewhere-will dig it out.
I was using it to build drum synths.
nix
Postby nix » Thu Mar 06, 2014 10:00 pm
env analyser.fsm
(244.52 KiB) Downloaded 940 times
nix
Postby djbrynte » Fri Mar 07, 2014 12:05 pm
Some how i cant connect the stream even if its same stream as before.
djbrynte
Postby nix » Fri Mar 07, 2014 7:12 pm
Try turning the gate off, or triggering the envelope.
nix
Postby djbrynte » Fri Mar 07, 2014 7:14 pm
Nope dident solve the problem :/
djbrynte
Postby Jay » Sat Mar 08, 2014 10:37 am
it wont connect because of the poly analyzer m8! so what you have to do is duplicate your adsr module inside your adsr block and feed the env analyser with a seperate adsr signal!
like this!
env analyser.fsm
(258.15 KiB) Downloaded 951 times
Regards
Jay
Postby djbrynte » Sat Mar 08, 2014 11:48 am
Ah ok thnx now i think i got it!
djbrynte
Users browsing this forum: Majestic-12 [Bot] and 13 guests
