Assembler
Assembler
Postby User108 » Thu Mar 13, 2014 10:32 pm
How can I create assembler primitive's string/integer/etc array input and output? Have seen somewhere on SM forum a schematics screen shot, but cannot figure it out how it was done in any FS manual. Basic example of how to add 2+2 with output appreciated. Thank you.
HiAsm - A Visual Programming IDE for ALL programming languages:
https://hiasm.com
User108
Re: Assembler
Postby KG_is_back » Fri Mar 14, 2014 3:06 pm
Assembler primitive is made for DSP (digital signal processing). It handles inputs and outputs on sample-by-sample basis. Currently it supports only floating point SSE input/output. Even if you connect green component to that input it will be converted to Floating point first. To process green data like arrays (of any type) use ruby component.
KG_is_back
Re: Assembler
Postby User108 » Fri Mar 14, 2014 9:16 pm
Thanks for clarification, but I bet I really saw a screenshot where asm primitive had a string array input! May be later I'll find it again to show here.
https://hiasm.com
User108
Re: Assembler
Postby KG_is_back » Fri Mar 14, 2014 11:36 pm
User108 wrote:Thanks for clarification, but I bet I really saw a screenshot where asm primitive had a string array input! May be later I'll find it again to show here.
I'm pretty sure you are either wrong or it was just photoshoped for use in context. the ASM in FS/SM has no instructions to handle strings or string arrays. you can't even (officially) input integers (although you can process them internally).
KG_is_back
Re: Assembler
Postby tester » Sat Mar 15, 2014 3:21 am
There should be some assembler tutorials on synthmaker forum. I remember cyto did some tools for that.
http://synthmaker.co.uk/forum/viewtopic ... 76&p=86527
http://synthmaker.co.uk/forum/viewtopic ... 33&p=85291
Just rename osm to fsm; it will load in FS.
tester
Re: Assembler
Postby User108 » Sat Mar 15, 2014 10:55 am
Thanks, Tester. Finally I've found it - here's asm with array input:
http://www.synthmaker.co.uk/forum/viewtopic.php?f=5&t=10248&p=76918
asm array_orig.jpg (74.3 KiB) Viewed 11411 times
Seems to be photoshoped for a feature request indeed.. Hate Photoshop now))). But looks really cool.))
https://hiasm.com
User108
Re: Assembler
Postby User108 » Sat Mar 15, 2014 11:09 am
https://hiasm.com
User108
Users browsing this forum: No registered users and 78 guests
cron
