Mix
Re: Mix
hello mit2
not sure what you want -
a switch: would be your described if else scenario
a crossfade: fades from A to B mixing the signals
here are the 2 modules (for stream as code)
- crossfade_n_switch.fsm
- (1.42 KiB) Downloaded 836 times
Nubeat7 - Posts: 1347
Re: Mix
you mean
if mix == 0 then dry input
if mix > 0 then wet *mix
would be like this then
you just need to change 'b' to '(b*mix)' in the switch module
btw are you sure you didn`t confuse > (greater then) and < (less then)
also where is the double stream?
if this doesn`t help,you better post a schematic..
streamin a; //dry in
streamin b; //wet in
streamin mix;
streamout out;
out = (a&(mix<=0))|((b*mix)&(mix>0));
Re: Mix
streamin dry;
streamin wet;
streamout out;
streamin mix;
out=wet*mix+dry*(1-mix);
Re: Mix
KG_is_back wrote:
streamin dry;
streamin wet;
streamout out;
streamin mix;
this is also a crossfade...
i just use this instead:
out = a - (a - b) * fade;
because of less multiplication - it should be with better performance if i`m right and it has no extra float value for 1, but KG`s is easier to understand?
so you want:
and if mix < 0 (less then zero) it mixes the wet signal(with the filters) without input signal
so 0..-1 should mix the wet signal?
then just xchange the > and < signs in the code above
streamin a;
streamin b;
streamin mix;
streamout out;
out = (a&(mix==0))|((b*mix)&(mix<0));
note that the mix signal then needs to be 0..-1 and not like you wrote before 0..1
if mix range would be 0..1 in your scenario:
mit2 wrote:i want doit this if mix = 0
http://i61.tinypic.com/286toa8.jpg
and if mix < 0
http://i62.tinypic.com/1zovvde.jpg
this is schematic how has a look
it never can get the second signalway because mix is never < 0
Users browsing this forum: Google [Bot] and 92 guests
