drop list problem.
drop list problem.
Postby Freddymusic » Fri Apr 11, 2014 2:45 pm
Hi
When the daw is playing the midi, and plugin is work, the drop list is make a problem if i click on it. Sound will fall silent.
When the daw is stopped it's work perfectly. When i use a simple drop list without any green contact, the bug is still here. I removed the preset menager, and the preset modul, but the bug is here. I'm using SM. I opened it in FS and a replaced the old drop list. Now it's good with the new module, but i want to repair in SM. Is it possible?
freddymusic.hu
Freddymusic
Re: drop list problem.
Postby CoreStylerz » Fri Apr 11, 2014 3:03 pm
Make sure that preset manager is not set to recompile, kill voices.
PM me if you are interested.
CoreStylerz
Postby Freddymusic » Fri Apr 11, 2014 3:17 pm
I tired it, but it's not solution. :(
freddymusic.hu
Freddymusic
Postby CoreStylerz » Fri Apr 11, 2014 4:07 pm
Post your osm.
CoreStylerz
Postby Freddymusic » Fri Apr 11, 2014 6:20 pm
When i remove a lot of module, it's work. Somewhere something make this problem. If i can't find it, i will post.
freddymusic.hu
Freddymusic
Postby Walter Sommerfeld » Thu May 15, 2014 10:14 pm
@CoreStylerz:
Man! - where did you get this info from???
I disabled all Modules in my standalone effect because i had dropouts while changing presets... :(
Only 2 find the Preset Manager is the bad ass...
No doc or Changelist Info about the new Options Input in the Preset Manger: 1=NoMute, 2=NoKillVoices, 4=NoRecompile
1=NoMute did it 4 me :)
cheers,
Walter
P.S.: Just found out that my Preset Manager Modul in my Toolbox missed the Int 7(default?) in the Options Input...
Preset Manager Options FAQ.png (28.21 KiB) Viewed 10846 times
Walter Sommerfeld
Postby RJHollins » Thu May 15, 2014 11:41 pm
wow ... I never noticed this in the manager :oops:
now I need to check some of my projects.
Users browsing this forum: No registered users and 52 guests
