Chronometer
Chronometer
Postby rustyou » Fri Apr 11, 2014 12:06 pm
Hello,
I'ld like create a stopwatch.
With 2 btn for go and stop chrono.
there is an example ?
rustyou
Re: Chronometer
Postby CoreStylerz » Fri Apr 11, 2014 4:15 pm
Only for chronometer?
Just use ruby ticker to 1 sec and you will get 1 tick every second.
Make a counter and set max 60 to get minutes and so on...
Display counter values.
PM me if you are interested.
CoreStylerz
Re: Chronometer
Postby rustyou » Fri Apr 11, 2014 5:42 pm
hi CoreStylerz,
Yes.
1 btn for start. and 1 other btn for stop time
rustyou
Re: Chronometer
Postby rustyou » Fri Apr 11, 2014 5:43 pm
i am bad with ruby :(
rustyou
Re: Chronometer
Postby tester » Fri Apr 11, 2014 7:37 pm
Check in the toolbox for the ruby module that was described. Using it - does not requires knowing how ruby works.
tester
Re: Chronometer
Postby KG_is_back » Fri Apr 11, 2014 9:00 pm
This one uses code counter. start and stop toggle a boolean and that controls a counter within an assembly code. After that the counter is divided by samplerate and you get very precise time in seconds
Chronometer.fsm
(1.96 KiB) Downloaded 796 times
KG_is_back
Re: Chronometer
Postby rustyou » Fri Apr 11, 2014 9:38 pm
Just prefect !!
Thank you KG :) !!!!!!
rustyou
Re: Chronometer
Postby RJHollins » Fri Apr 11, 2014 9:41 pm
Thanks KG !!
One for the toolbox ... cause ya just never know ;)
Re: Chronometer
Postby CoreStylerz » Sat Apr 12, 2014 12:37 am
I've build a green+ruby ticker chronomater.. 4-5 minutes.
Here is:
Chronometer.fsm
(5.05 KiB) Downloaded 819 times
Ability to start, stop and reset timers.
Also decimals for seconds.
Kg module is ok, but requires audio load.
CoreStylerz
Re: Chronometer
Postby KG_is_back » Sat Apr 12, 2014 1:26 am
CoreStylerz wrote:I've build a green+ruby ticker chronomater.. 4-5 minutes.Here is:
Chronometer.fsm
(5.05 KiB) Downloaded 3 times
Ability to start, stop and reset timers.Also decimals for seconds.Kg module is ok, but requires audio load.
Very cool...
Yes you're right about the audio load, but the advantage of my chronometer is, that it is controlled by streamboolean (or defacto by any stream) so it can be sample-precise when triggered by streams.
KG_is_back
Users browsing this forum: Google [Bot] and 59 guests
