display error
display error
Postby rustyou » Sat Jul 05, 2014 10:32 am
Hello,
I've a calcul who display the error : 1.#INF
Because the calcul is : 0/0 . this is normal
But for the user, i would like display 0 .
How shall we do it?
Thanks
calcul.fsm
(7.49 KiB) Downloaded 720 times
rustyou
Re: display error
Postby Drnkhobo » Sat Jul 05, 2014 10:57 am
Drnkhobo
Re: display error
Postby TheOm » Sat Jul 05, 2014 10:59 am
Very simple. Just check if the result is infinity and use a selector to display 0 instead.
calcul.fsm
(2.63 KiB) Downloaded 727 times
TheOm
Re: display error
Postby rustyou » Sat Jul 05, 2014 11:28 am
Oh yes perfect thank you.
And for the flaot.
I want to display just one 0 for the user and no 0.0. But i want to display the decimal too....?
rustyou
Re: display error
Postby TheOm » Sat Jul 05, 2014 12:08 pm
Like this?
calcul.fsm
(1.58 KiB) Downloaded 739 times
TheOm
Re: display error
Postby tester » Sat Jul 05, 2014 12:34 pm
@TheOm - can you check if you can open your last schematic by double clicking on it?
It's one of these cool examples, that crash Flowstone. ;-)
BTW, if it crashes on your machine as well - send it to support.
tester
Re: display error
Postby rustyou » Sat Jul 05, 2014 4:33 pm
Yes great :)
thank you for your help TheOm
rustyou
Re: display error
Postby TheOm » Sat Jul 05, 2014 5:29 pm
tester wrote:@TheOm - can you check if you can open your last schematic by double clicking on it?
Sorry can't check. I'm using the FL-Studio plugin version, so I always have to use the Open-File dialog.
TheOm
Re: display error
Postby tester » Sat Jul 05, 2014 7:52 pm
Okay, I sent it to Malc.
This is one of these situations in which when you start the schematic by double click on it (i.e. not drag and drop to FS nor load via menu) - it crashes FS. I checked on two machines and is the same. Appearently it has to do with some sort of initialization order between FS guts and ruby.
@Nubeat7 - it's one of these spooky scenarios I talked about. Probably will be fixed with the next release.
tester
Re: display error
Postby Nubeat7 » Sat Jul 05, 2014 8:55 pm
tester wrote:@Nubeat7 - it's one of these spooky scenarios I talked about. Probably will be fixed with the next release.
no idea what you are talking about? everything works normal here...
Users browsing this forum: No registered users and 92 guests
