'is playing' stream primitive doesn't work
Postby Nubeat7 » Wed Jul 16, 2014 4:22 pm
i think we already had this theme up a while ago, just wanted to confirm this bug..
the 'is playing' stream primitive doesn't work when exporting it as vst
here is the example - i tested it in cubase and renoise
if somebody could confirm this it should be reported, thx.
playtest.fsm
(14.58 KiB) Downloaded 849 times
Re: 'is playing' stream primitive doesn't work
Postby billv » Wed Jul 16, 2014 7:44 pm
Nubeat7 wrote:'is playing' stream primitive doesn't work
It does work....
but packing the 'is playing' output , like in your fsm...there's no output...don't know why.
billv
Postby Nubeat7 » Wed Jul 16, 2014 7:56 pm
and in which case does it work? i tried all 3 cases (poly, mono, mono4) and no of each did work... :(
Postby billv » Wed Jul 16, 2014 9:42 pm
I just used a mono readout attached to prim.
billv
Postby Nubeat7 » Wed Jul 16, 2014 9:51 pm
don't work here...
anyway it should make no difference to use it in poly, mono or mono4..
Postby trogluddite » Wed Jul 16, 2014 10:03 pm
Broken here in Reaper for the posted Mono4 schematic.
Postby Nubeat7 » Wed Jul 16, 2014 10:16 pm
thanks for confirming, should i report it using support@dsprobotics.com or do you trog or exo get in touch with malc soon? to be sure they get it..
Postby billv » Thu Jul 17, 2014 6:17 am
Yeh nubeat7...there defiantly seems to be a bug there somewhere....
In the meantime, here's a way of working around it that might help...
I'm testing in FL....
Nothing works in this pic....
Then, for some reason, just drop this into schematic..
And everything works.... :? :?
give it a try with your fsm...weird... :?
billv
Postby Nubeat7 » Thu Jul 17, 2014 9:51 pm
thanks billy, i know, normally i use the green version but i need the blue one in my actual case..
i reported this to the support.
Postby billv » Thu Jul 17, 2014 9:58 pm
I didnt clarify this...but dont connect the green/ruby
prim...just drop it into schematic un-connected..
and still use the blue.
billv
Users browsing this forum: No registered users and 69 guests
