Fade In LFO - Best Technique
Which technique you use to implement a fade-in to a LFO?
The concept would be to have a single envelope with attack and control the amplitude-stream of the LFO,
but as you well know to implement an envelope is always linked to a stressful computing for CPU,
you know or use other techniques to do this?
- Tronic
Re: Fade In LFO - Best Technique
For a synth?
Something like this should be enough....
That should work for you. I don't think there is a simpler way than that.
streamin lfo;
streamin fadeInTime;
streamin sampleRate;
streamout fadeInLfo;
float increment;
float fadeIn;
stage(0)
increment = fadeInTime / sampleRate ;
fadeIn = 0; //reset for every new voice
fadeInLfo = fadeIn * lfo;
fadeIn = min(fadeIn + increment, 1);
- Exo
Or alternatively you may use exponential fade in (basically the same idea of implementation as Exo's but different envelope shape)
fadeCoef has to be calculated too. Generally it is e^(-1/T) where T is release time in samples.
Note that Release time is not the time it takes for the decay to reach 0, but 0.3679 instead. (exponential curve never really reaches 0).
Exponential curves often sound more natural to human eat than linear.
streamin lfo;
streamin fadeCoeff; //this is number usually around 0.9 (always 0-1 range)
streamout out;
float cut=1;
out=lfo*(1-cut); //cut is 1 on start and decays to zero over time
cut= cut*fadeCoeff; //fade coeff controls how fast cud decays
Thx for this code hint.
- Tronic
Users browsing this forum: No registered users and 74 guests
