Ruby GraphicsPath save error?
Postby KG_is_back » Sat Oct 04, 2014 3:59 pm
Here is the thing. I want to pass a GraphicsPath form one ruby component to another but when I save the schematic I get an error "(in method 'saveState') no _dump_data is defined for Class GraphicsPath"
I believe the problem is, that the Path cannot be saved as part of inputs and outputs (which are saved and loaded by default in ruby). I do not need to save the path, but I need it to pass from one component to another. What should I do?
pathproblem.fsm
(321 Bytes) Downloaded 808 times
KG_is_back
Re: Ruby GraphicsPath save error?
Postby billv » Sun Oct 05, 2014 12:30 am
KG_is_back wrote:pass a GraphicsPath form one ruby component to another
What if you write the method inside a class like..
class GraphicsPath
def rect
return [0,0,10,10]
# then in other ruby prim...
mypath = GraphicsPath.new
mypath.rect
Would this work for you ?
billv
Postby KG_is_back » Sun Oct 05, 2014 12:57 am
class GraphicsPath
def rect
return [0,0,10,10]
mypath.rect
Unfortunately that would not work. The example schematic contains the path contains only one rectangle just to show the problem. The path I'm using in my original schematic contains several shapes.
But it gave me an idea oh how to fix the problem. I do not really need to save the path - I just need to prevent the error massage to show. So what if I add a dummy "_dump_data" method to graphicsPath class that simply outputs nil. That should fool the FS not to show error. And similar thing would probably be needed for loading... I'll give it a try.
KG_is_back
Postby billv » Sun Oct 05, 2014 1:28 am
So its not viable/possible to just re write your
original inside the class and add all your shapes
inside new def's there....Ok....Hope you find right solution.
billv
Postby KG_is_back » Sun Oct 05, 2014 1:36 am
Yes!!! IT WORKS... it is something called marshal module...has functions _dump and _load to deal the saving and loading data... some classes do not have these functions defined, so they output error. I just added "dummy" versions of these methods GraphicsPath class and errors are gone
class GraphicsPath
def _dump level
def _load args
KG_is_back
Postby billv » Sun Oct 05, 2014 1:56 am
Great :) ..will take another look at Mr Marshall..interesting fix..
billv
Postby RJHollins » Sun Oct 05, 2014 6:14 am
Ahh ... the 'Marshall' routine.
Mr NuBeat has done some extensive work on this very useful function.
I think NuBeat started to help me on this over at the SM forum. For what I needed to do, this 'Marshall' technique of saving and loading configuration data simplified the entire process and array management.
I continue to thank NuBeat for this, and all his other generous help and educating :D
Postby KG_is_back » Sun Oct 05, 2014 10:04 am
RJHollins wrote:Ahh ... the 'Marshall' routine.
ah yes I remember that... it was something about array of arrays, that the top array contains only pointers to the sub-arrays. when you create a copy of the top array and change the element in the sub-array both copy and original will be affected. We needed the mashall routine to create a hard copy to make the copy and original change values separately.
KG_is_back
Postby RJHollins » Sun Oct 05, 2014 6:53 pm
One of the very handy features using the 'Marshall' routine had to do with variable sized array management. It automatically handle all those details.
Postby RJHollins » Tue Oct 07, 2014 8:53 am
I went searching for the thread[s] both here and on SM for the 'Marshal Method' ... I couldn't find it :roll:
We were doing all kinds of testing to save/load files while dealing with some strange compatiability issue ... it was a real crazy time.
If I find the threads I'll try to post them.
Users browsing this forum: No registered users and 84 guests
