Easy rotation of Knobs
Postby glitchcpt » Tue Nov 11, 2014 11:22 am
Is there an easier way of creating knobs than using animations with a bunch of cells?
Is there a way of maybe ruby calculating the rotation and applying it to a static PNG (with single cell) image?
Thanks
glitchcpt
Re: Easy rotation of Knobs
Postby KG_is_back » Tue Nov 11, 2014 11:41 am
You can use rotate prim to rotate parts of view. If I recall correctly Ruby contains similar command, so it should be possible there too
rotation knob.fsm
(1.38 KiB) Downloaded 692 times
KG_is_back
Postby glitchcpt » Tue Nov 11, 2014 12:49 pm
Wow! this is perfect :)
Legend
glitchcpt
cron
