Help with Morphing X/Y Oscillator
Hey guys,
So I had an idea for an oscillator using an X/Y to morph between 4 different shapes,
but again I think I have gone blank on the maths for how its suppose to work, the result I have so far is an interesting effect but it is not exactly how I wanted it, basically the idea is to have the exact waveform when the cursor is in one of the 4 corners of the X/Y and then it slowly morphs into the other waveforms the closer it gets to the other corner.
Thanks for your help guys
xy osc.fsm- (24.19 KiB) Downloaded 1143 times
- glitchcpt
Re: Help with Morphing X/Y Oscillator
so you have 4 oscillators. Lets name them based on the XY position that specifies them. We use Y coordinate to morph between left top and left bottom as well ass right top and right bottom. Then we use X coordinate to morph between the result of left side and right side.
Yes, that is exactly the idea.
They seem to pop out the other side as sums of each other etc
:edit:
I think i see where I went wrong
:edit:
- glitchcpt
Thanks for your help!
Got it working, here it is:
xy osc edit.fsm- (22.11 KiB) Downloaded 1167 times
- glitchcpt
nice one thank you Glitchcpt for sharing it.
Nubeat7 - Posts: 1347
Shouldn't they just be sums anyways?
- Perfect Human Interface
Perfect Human Interface wrote:Shouldn't they just be sums anyways?
My idea was to have the pure waveforms when the X/Y selector is in one of the four corners
- glitchcpt
So I am trying to add a second oscillator, using the same panel, OSC1 using left click and OSC2 using right click.
The right clicks code, doesn't release the node when I let go of the mouse button, I think I missed something in the original code,
the example is attached
xy osc edit Rclick.fsm- (160.27 KiB) Downloaded 1144 times
- glitchcpt
The "mouseRUpcaptured" method should be named "mouseRUp" ...You just did a typo I believe.
I just copy pasted from someone elses code, so that is probably the case
- glitchcpt
