Process MIDI data?
Re: Process MIDI data?
Postby oddson » Thu Dec 25, 2014 10:02 pm
oddson wrote:...While [green solutions] can be easy to understand when simple they can get pretty messy once you start including complex behaviour.
Not to say you can't build them in a way that they can be deciphered.
This one can filter by channel, map linearly between floor and ceiling (min and max) limit or just clamp to limits.
linearVelocityMapper.fsm
clamp velocity to limits or map linearly to limits
(2.44 KiB) Downloaded 910 times
oddson
Postby tulamide » Fri Dec 26, 2014 1:04 am
While you're right, I just wanted to encourage people to give your green solution a chance. Ruby is more of an advanced topic and involves knowledge of traditional programming. So I recommend trying to find green solutions first, if the people are just starting out.
In fact, I still see green as the foundation, with Ruby as an extension or addition for very special cases.
Postby daslicht » Sat Feb 07, 2015 8:18 pm
tulamide wrote:While you're right, I just wanted to encourage people to give your green solution a chance. Ruby is more of an advanced topic and involves knowledge of traditional programming. So I recommend trying to find green solutions first, if the people are just starting out.
Actually I find Ruby more easy than the green, but I might be a bit biased by my job as web developer :)
daslicht
Previous
Users browsing this forum: No registered users and 59 guests
