Help: Ruby 4 x Sample & Hold Value
Postby Walter Sommerfeld » Thu Jan 29, 2015 10:12 pm
Well... this Value thing in ruby makes me crazy...
I need ur help guys:
What i need are 4 sampled values... sounds easy but:
i can't get it to work :o
maybe it should be done all in one ruby part?!
and maybe i'm missing here something :?
So just simply click the dice 4 times and try to recall the sampled values with the knob :(
Walters dice 4 x Value Sample.fsm
(please ignore the simple dice part)
(264.29 KiB) Downloaded 784 times
Walter Sommerfeld
Re: Help: Ruby 4 x Sample & Hold Value
Postby Tronic » Thu Jan 29, 2015 11:32 pm
semplify all with this?
watch 'number', number = [ [*1..6].sample, [*1..6].sample, [*1..6].sample, [*1..6].sample ]
number[@select] # the var @select is an ruby int input named select
Tronic
Postby Walter Sommerfeld » Thu Jan 29, 2015 11:46 pm
Hi Tronic,
thanks but:
i only need a value selector that is working (see the not changing output label when u rotate the knob)
...ignore the dice part
Walter Sommerfeld
Postby Tronic » Fri Jan 30, 2015 12:03 am
Yes the ruby connector not have the same concept of the green < - >, so you have retrigger it with the ruby.
However the my example is the simply version of your schematics, it act in the same manner, just use an knob to get the value of results.
def event i
   if i=="dice" # get trig from dice button?
      output 0, a=[*1..6].sample
      output 1, b=[*1..6].sample
      output 2, c=[*1..6].sample
      output 3, d=[*1..6].sample
      @number = [a,b,c,d]
   output 4, @number[@select] #@select is knob input value
Tronic
Postby Walter Sommerfeld » Fri Jan 30, 2015 1:28 am
I need 4 sampled values selectable from the same value source!
Not four selectable random numbers.
The dice is only a simple 'generator' to get 4 values for the selector!...
Please have a closer look - Thanks again
Walter
Walter Sommerfeld
Postby tulamide » Fri Jan 30, 2015 1:36 am
Walter Sommerfeld wrote:I need 4 sampled values selectable from the same value source!
Walter
Something like this?
EDIT: No, can't be what you're looking for, I just saw that Tronic already offered bqasically the same, meaning a selection is done by the knob from a pool of several values.
selection.fsm
(4.46 KiB) Downloaded 766 times
Postby Walter Sommerfeld » Fri Jan 30, 2015 10:24 am
YUP tulamide,
but thanks anyway...
U guys put me on the right track...
but i guessed it ends up with a selector made inside a ruby mod by using variables to mimic the S&H...
My intention
here is needed because i have a very complex Midi Controller project where i need to S&H 4 banks of values so i don't have to calculate them every time again and again!
After ur hints and sleep over it i think i got it (on paper)... ;-)
Will report later...
Walter Sommerfeld
Postby Walter Sommerfeld » Fri Jan 30, 2015 11:41 am
Here my working if/elsif version!
If some of u like to make a simpler version with in 'case' etc. - you're welcome...
keep on doing!
Walter
4 Values s&h in ruby by sunsynth.fsm
finally it is working (i hope)
(15.54 KiB) Downloaded 745 times
Walter Sommerfeld
Postby Tronic » Fri Jan 30, 2015 3:36 pm
this is my simplification
def init
@SH = []
def event i, v
   if @on and (i=='go') and (@selection<=@max)
      @SH[@selection] = @input_value
   output @selection, @SH[@selection]
   output 'done_v', nil
   output 'done', nil
Tronic
Postby Walter Sommerfeld » Fri Jan 30, 2015 5:33 pm
works fine... but:
where my version triggers one time after hit go - yours produces 3!
cheers,
Walter
Walter Sommerfeld
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 79 guests
