Int Array Help
Int Array Help
Hello guys. Can somebody help me with small problem? I need to swap values in integer arrays. I know ho to easilly do this in ruby but i need solution with green primitives since i dont want to use ruby at all.
I need this for module/effect ordering. So for example I have array with six integers 0,1,2,3,4,5 and i need to swap two choosen values. For example 0 with 3. I have tried to do it by myself but no good working soluton.
TrojakEW - Posts: 111
Re: Int Array Help
Inside the Developer toolkit in the Array section is a "Sort integer array" module, have a look at that it uses swapping to sort the array. Maybe you can learn from or modify it for your needs.
- Exo
Re: Int Array Help
Thanks you guys. I will check booth and see what is best for me.
Re: Int Array Help
Well I found the same problem in booth version and in my own attempt too while swaping the array. Problem is when I want to use array from output again for another swap. Look in attached file - I used Yoleen example. Try to change index few time and you will see the problem. It will add same value to two indexes after 2 or more changes. How to fix that?
- Swap_loop.fsm
- (488 Bytes) Downloaded 778 times
Re: Int Array Help
Hmm, perhaps a trigger order issue? Here is an alternative using code instead of green.
- SwapIntArray.fsm
- (766 Bytes) Downloaded 810 times
martinvicanek - Posts: 1328
Re: Int Array Help
here is a green version which should work correct
- Swap_array_elements_green.fsm
- (578 Bytes) Downloaded 776 times
Nubeat7 - Posts: 1347
Re: Int Array Help
This should work correctly now in loop.
- Swap V2.fsm
- (486 Bytes) Downloaded 779 times
- Youlean
Re: Int Array Help
Thanks. Going to test them today.
Re: Int Array Help
My version is quite similar to Nubeat7's...
- Swap (MyCo).fsm
- (1.24 KiB) Downloaded 757 times
MyCo - Posts: 718
Users browsing this forum: No registered users and 36 guests
