Stream Sample and Hold Problem.
Postby Perfect Human Interface » Sat May 23, 2015 9:02 am
I'm having trouble getting anything out of this stream Sample and Hold module. If anyone could tell me what I'm doing wrong that would be appreciated!
Sample and Hold Problem.fsm
(9.68 KiB) Downloaded 737 times
Re: Stream Sample and Hold Problem.
Postby nix » Sat May 23, 2015 9:36 am
Heya!
Glad I can help.
The 0 crossing s&h need to rise from minus to plus to sample->
Sample and Hold Problem_mod.fsm
(10.01 KiB) Downloaded 750 times
Enjoy the linkage
nix
Postby Perfect Human Interface » Sat May 23, 2015 11:19 pm
Thanks so much Nix!
Looks like whomever wrote this left out an equals sign.
Now it works in the 0 -> 1 case.
Postby Youlean » Sun May 24, 2015 12:10 am
If you need, here is immediate sample and hold...
Hold.fsm
(304.19 KiB) Downloaded 727 times
Youlean
Postby Perfect Human Interface » Sun May 24, 2015 12:24 am
That's an interesting method Youtlean. You could add a line to make it hold when > 0 rather than just either 0 or 1.
Perhaps this is slightly faster than the above?
Postby Perfect Human Interface » Sun May 24, 2015 12:52 am
Here, I took Youlean's code and tweaked it so it accepts stream bool or zero cross. Stream bool is probably the best method overall since you can use them with the stream compare prims.
Edit: Ok so just so it's clear to everyone (now that I realize it myself) this kind of "sample&hold" only holds so long as the bool is true and passes the signal otherwise, while the above module I was originally working with samples when the control value goes from <0 to >0 and holds until the next time it samples. Useful for different things.
Hold_PHI edit.fsm
(585.56 KiB) Downloaded 744 times
Users browsing this forum: No registered users and 58 guests
