binary search
binary search
hi im a beginer
can anybody help me to convert this code (c++) to ruby(works in flowstone) ??
#include <conio.h>
#include <iostream.h>
main()
int n;
cout<<"array size???" ;
cin>>n;
cout << "_____________";
cout<<endl;
int a[n];
for(int i=0;i<n;i++)
cin>> a[i];
cout<<endl;
cout<<endl;
for(int i=0;i<n;i++) //sort
for(int j=0;j<n-1;j++)
if(a[j+1]>a[j])
int temp=a[j];
a[j]=a[j+1];
a[j+1]=temp;
for(int i=0;i<n;i++) //namayesh
cout<<a[i]<<" ";
cout<<endl;
cout<<endl;
int f;
cin>>f;
int start=0; //Binary search
int end=n-1;
while(start<=end)
int mid=(start+end)/2;
if(a[mid]==f)
cout<<"found at "<<mid;
break;
if(a[mid]<f)
end=mid-1;
else if(a[mid]>f)
start=mid+1;
if(start>end)
cout<<"Not found!";
getch();
- looji
Re: binary search
The question is if you gain any advantage from it. Binary search, a divide and conquer algorithm, is very stable and therefore the best choice for very large arrays. However, in pure Ruby the code gets interpreted, while the built-in search methods are compiled c-code.
binary search needs a sorted array to start with. You sort an array simply by using
For the binary search, there's a premade code block on codecodex, using recursiveness:
If this doesn't help you, please provide a description of how you want to make use of it.
myarray.sort!
def binary_search(array, key, low=0, high=array.size-1)
return -1 if low > high
mid = (low + high) / 2
return mid if array[mid]==key
if array[mid] > key
high = mid - 1
else
low = mid + 1
binary_search(array, key, low, high)
Users browsing this forum: Google [Bot] and 50 guests
