Sample acurate timing - well where?
• Page 2 of 2 • 1, 2
Re: Sample acurate timing - well where?
user_fm wrote:....means it makes no sense to extract float from mono stream with 1ms timer (1000 times per seconds) ?
If you want to pull samples out of a mono stream with exact precision then you can use the new Mono To Frame components. These use Ruby Values and hence the new events system for timing.
If you want to pull a single float precisely every 1ms then use the version that allows you to specify the number of samples:
and send a value of 1 to the Samples input every 1ms.
support - Posts: 151
Very old thread I know, but there isn't any sound at all. Im using an asio driver btw.
- Halon
Welcome Halon!
post your schematic if you like
nix - Posts: 817
Users browsing this forum: No registered users and 67 guests
