memin in DSP moduls.
Postby KimSteff » Thu Aug 20, 2015 2:40 pm
In the user guide it is statet that you can use memin in the DSP Code modules.. However as fare i can make it to work it is only in the assembler modules it is possible. Can that be right ? I like to pass controle parameters to a DSP module.. A lot of controle parameters.. So i am not interested in using streamin. But a way to be able to read from a array or memoryblock inside the DSP Code module..
KimSteff
Re: memin in DSP moduls.
Postby MyCo » Fri Aug 21, 2015 2:52 am
You can use it in DSP code as well... see:
memin (MyCo).fsm
(122.29 KiB) Downloaded 853 times
MyCo
Postby KimSteff » Fri Aug 21, 2015 8:50 am
Hi and Tanks. For some reason my flowstore version 3.0.4 goes down when trying to open your file. So i cant se how you do it! Is can you make a printscreen or something ?
Thanks
KimSteff
Postby KG_is_back » Fri Aug 21, 2015 9:48 am
The feature was added in version 3.0.5 so unfortunately you can't use it in 3.0.4.
KG_is_back
Postby KimSteff » Fri Aug 21, 2015 10:22 am
Yes i can se it in the FlowStone Version History and Release Notes!
Well.. God reason for me to get a new support licens :-)
KimSteff
Users browsing this forum: Google [Bot] and 48 guests
