Circular Buffers
Circular Buffers
Postby BobF » Mon Oct 19, 2015 8:07 pm
Hello all, well mostly programmers. While doing some research for a Flowstone module I am working on I kept cumming across talk about "Circular Buffers". From what I have read they can be used for Delays, Revere Delays, Tapped Delays, Stretched and Compressed Audio, Pitch Shifting, and more.
So I was wondering, could a generic "Circular Buffer" be made as a module with some pointers on how to us it for the above mentioned effects and so on?
Martin, tulamide, MyCo, KG_, any ideas or suggestions?
Now I am sorry because I am defiantly not a programmer and can not join in on this project, but I sure hope other will!
Well that's it. Later then, BobF.....
BobF
Re: Circular Buffers
Postby Spogg » Tue Oct 20, 2015 8:19 am
Hear hear!
One of my future projects will be to fool around with a multi-tapped delay. If I get interesting results I'll make a module. There's nothing done towards this yet so your idea may lead to some useful ingredients. Otherwise it's just several existing delays in series and there may be a better way.
I've looked into commercial multi-taps and the approach varies considerably; there doesn't seem to be a consensus on the "best" way to do it so this will also interest me.
Even if I don't use what's uploaded it will doubtless be fascinating!
So guys... we're all waiting... :D
Postby BobF » Tue Oct 20, 2015 9:45 pm
CircularBuffer.fsm
(489 Bytes) Downloaded 1611 times
Ok Gang,
After hours of searching on the net I found this in a OLD Synthmaker blog. I typed it into the DSP box, but as you can see , it does not work. I do NOT know who wrote it, how it was supposed to work, or if it is even complete, but it was said to be a "Circular Buffer"
So if anyone who knows this stuff would PLEASE take a like at it, we would really be grateful (I guess Spogg and I, so far) Many thanks in advance!
Later then, Bob.....
BobF
Postby martinvicanek » Wed Oct 21, 2015 3:01 am
The declaration shouldread
float buffer[44100];
to make it work. Ring buffers are omnipresent, just look inside the stock delay. For more efficiency you want to go asm, refer to KG's post on FS Guru.
Postby BobF » Wed Oct 21, 2015 2:23 pm
Hi martin,
Thanks for the feedback, much appeciated!
BobF
Return to DSP
