Clock Accuracy - 10ms?
Re: Clock Accuracy - 10ms?
Todays hardware performance is amazing, isnt it?
martinvicanek - Posts: 1328
Yeah man,
FS is sample by sample.
You can get 128k out of it too.
nix - Posts: 817
martinvicanek wrote:Todays hardware performance is amazing, isnt it?
Hahah, I don't mean this. I mean that such code:
i = i + speed;
i = i&(i<samples);
processed at different clock (44100hz as you noticed) instead of 48Khz, makes huge differents if I use it for read sample from a Read module (as you suggested). Because it increase the speed of the whole process.
It is not a simple "for statement" that try to iterate in the slower time (more CPU you have, more faster it will be). Its a "for" that must iterate in a fixed time (i.e. sync). Am I right?
nix wrote:Yeah man,
But not every kind of processing inside FS! Ruby code is way more slower.
For what I see, only DSP code get and stay in synch at that speed (and maybe also Assembler code).
- Nowhk
Anyway I think I'm making some other mistakes:
Without rely on Graph (I removed it; could be delayed as suggested), every time an integer in INDEX module is outputted, I should immediatly see the current sample of that index changing in the other SAMPLE module.
Instead they are way (waayy) to async. What am I missing dudes? Its somethings like 3/4 seconds delayed. Too heavy...
can't figure it out!
I guess that:
when i==0 output => -0.693325
when i==1 output => 0.755871
and so on. Instead it "change" around i=1.78 for example, and the first step is quicker than the others (i=1 happens quickly).
I guess that:
- Nowhk
Yep- only streams use samples.
I'll have a peek at your schematic over the weekend
nix - Posts: 817
nix wrote:Yep- only streams use samples.
Wow, thanks! You will make me very happy, because I need to made this kind of stuff for the project Ive in my mind. Stay tuned...
- Nowhk
hmm-
can I get the whole LFO schematic?
Do you need to use ppq?
ps- when you use .00001 as the counter iter,
it takes very long to count to 1, which is where it will register an integer step in the wave read
nix - Posts: 817
Hey again Nowhk,
I saw your post at Fruity, so I learnt more about the ppq hack.
Here is the counter I have modified->
So the string array and the counter read the same.
Does that help?
http://imageshack.com/a/img633/1214/qJgkVp.png
Does that help?
nix - Posts: 817
This might help.
Check the blue section in this modulator. (It's an old 'myco' circuit from way back.)
nix wrote:Hey again Nowhk,
Does that help?
Uhm, I don't understand your schematic: it's identical to mine! And in fact using "i + .00001" I've the same problem.
billv wrote:This might help.
Uhm, not really The method is the same (stream->read mem->ppq tick->out), but the problem is that the index/output of the stream seems not aligned with the DSP code. I can see the values change, but not at the correct integer time/index
- Nowhk
