A new approach to trigger limiting
Postby tulamide » Sun Dec 27, 2015 5:51 pm
While working on r2 of the True Vector Pad (yes, an update is coming soon!), I needed a trigger limiter for the preset parameters that are sent from the preset manager to the module. The limiter prim is bound to the redraw rate, so I thought a Ruby solution could work even when there are no redraw triggers.
I kind of was successful. Indeed my solution limits incoming triggers, but it is very inaccurate the higher the limit rate is set. For example, at 10 triggers per second the real output rate is around 9.6 tps which is ok. But at 30 tps the real output rate is around 23 tps, etc.
I've made a test schematic for all you Rubyists that you can play with and hopefully optimize!
Trigger Limiter.fsm
(2.78 KiB) Downloaded 1214 times
Re: A new approach to trigger limiting
Postby martinvicanek » Tue Dec 29, 2015 12:23 am
Here is an alternative. It has a queue with configurable length in case you don't want to lose triggers which come too fast. Set qSize = 0 if you don't care. qSize >= 1 will output the desired rate, qSize = 0 will result in less than that because no buffering takes place.
Trigger Limiter(MV).fsm
(3.13 KiB) Downloaded 1209 times
Postby tulamide » Tue Dec 29, 2015 12:14 pm
Nice! A queue of course! Went into my toolbox. Thanks!
Postby Tronic » Tue Dec 29, 2015 1:21 pm
I like to use this code for trigger limit, and also I can execute an block of code with it.
sorry only text editor avaible.... :|
I think it work....
def init
   @block_test = 0
def event i, v , t
   trigLimit(100) {
      watch "block_executed", @block_test+=1
      output 0, nil
def trigLimit(d,&block)
   @i ||=0
   if @i<d
      @i+=1
   else
      yield if block_given?
      @i=0
Edit: make the example more clear, for block.
Tronic
