empty-line indexes and items removal - ruby
Postby tester » Fri Jan 15, 2016 10:45 pm
Two arrays scenario.
array 1 contains some empty lines:
a1
b1
[empty line]
[empty line]
e1
f1
array 2 is full.
a2
b2
c2
d2
e2
f2
both arrays are identical in size.
in ruby:
1) How to get a list of indexes of empty lines in array 1?
2) How to use the list of (these) indexes, to remove corresponding lines in array 2?
p.s.: still on FS 3.8.
tester
Re: empty-line indexes and items removal - ruby
Postby tulamide » Fri Jan 15, 2016 11:04 pm
There is no such thing as an empty line in an array. Every entry in an array is an object. But you could use the nil-object.
Then this is doing what you ask for:
a1 = 1, 2, nil, nil, 5, 6
a2 = "a", "b", "c", "d", "e", "f"
a1.each.with_index {|v, i| if v == nil then a2[i] = nil end}
a2.compact!
#a2 is now ["a", "b", "e", "f"]
Postby tester » Mon Jan 18, 2016 8:13 pm
Thanks, will check it.
BTW, nil or empty - depends on layer of reference. On GUI layer it's empty line, for programming language - it's nil.
tester
cron
