quick way to strip lines from excel
Is there a quick way to strip multiple lines via ruby from excel copypaste content?
The problem is with empty cells on the beginning and end of the line. Cells are tab separated.
- lines and nils.fsm
- (331 Bytes) Downloaded 798 times
Re: quick way to strip lines from excel
Depends on what you want to do with the data. Should it stay text, including tabs? Or should it be a string array, where a tab without data before results in an empty string entry, like this:
tab5tabtab5return = ["", "5", "", 5]
Can be both, tab version goes for output.
Hope this helps?
- lines and nils[tula].fsm
- (625 Bytes) Downloaded 779 times
I'm not exactly sure how to send to output(s) selected input lines?
(I think I messed a bit the question too).
What I'm trying to get is something like on structure in schematic.
Theme 1: cleaning excel copy/paste content from unused lines ( = selecting desired lines), but keeping formatting (tabs),
Theme 2: from that output - selecting some individual lines as arrays (which will contain empty/nil lines, sometimes on the beginning or end).
Basically I'm trying design a sort of statistical calculation sheet for measuremental data.
- Schematic1.fsm
- (501 Bytes) Downloaded 803 times
Like this?
- Schematic1[tula].fsm
- (965 Bytes) Downloaded 777 times
Appearently there is some problem within it, because it works with simple matrix and produces an error with larger one. But I found a workaround, and it works.
For conversion between tabs and some reference mark I use something like this:
and then this little fellow works fine with indexes:
output @in.tr("\t","^")
output 0, @my_array.values_at(*@indexes)
Users browsing this forum: No registered users and 122 guests
