File Handling
Re: File Handling
Postby RJHollins » Thu Mar 10, 2016 9:04 pm
cool ...
Is there a way to RENAME a file [using RUBY] ?
Re: File Handling
Postby Nubeat7 » Thu Mar 10, 2016 9:11 pm
yes, just updated the list above..
for more watch here:
http://ruby-doc.org/core-1.9.3/File.html
Re: File Handling
Postby RJHollins » Thu Mar 10, 2016 9:47 pm
Thanks for the LINK. Was having trouble finding the Ruby 1.9.3.
BookMarked 8-)
Re: File Handling
Postby S1User » Thu Mar 10, 2016 9:48 pm
That's great. Now I just need to study Ruby to find out how to trigger subs with those code lines.
I know how to push strings in and out with "@" I/O, but not yet clear on how to trigger a Ruby sub on demand.
Ah... wait... I think I see. Just replace my modules with a Ruby module and those things will just run.
Great. Off to give it a go.
S1User
Re: File Handling
Postby S1User » Thu Mar 10, 2016 11:57 pm
Oh man. :shock: I've been working way too hard not using Ruby modules. This below is much cleaner than the rats nest of primitives I had doing the same thing before.
You guys are great.
Schematic: http://i.imgur.com/ynRhihi.png
S1User
Re: File Handling
Postby RJHollins » Fri May 13, 2016 6:44 am
Back to an issue I'm having :cry:
It seems FS RUBY does not have the FileUtils class.
What I'm trying to do is:
1. Copy a file to a new dest folder ... then,
2. Re-name the new [copied] file.
3. Insuring that the original file remains intact at original location.
I've used the posted 'File.rename(@old_name, @new_name)' , but it is removing the original file :roll:
Note: The goal. I have to make copies of a single file and rename them as new files in a new folder. There could be a dozen or more copies]. I'm using a filename list to increment through in the rename process.
Note 2. I also tried the EXEC primitive to do the copy. I can't seem to get that to work.
I suck :oops: :twisted:
Re: File Handling
Postby Walter Sommerfeld » Fri May 13, 2016 11:38 am
here a method 4U i got from DWB (hope he don't mind)
def copy_file(src,dest)
    File.open(src, 'rb') do |s|
        File.open(dest, 'wb', s.stat.mode) do |f|
            IO.copy_stream(s, f)
Keep on Doing!
Walter
Walter Sommerfeld
Re: File Handling
Postby RJHollins » Fri May 13, 2016 5:19 pm
Thanks Walter [....and DWB]
I'll give this a go when I get back.
Appreciate.
Re: File Handling
Postby RJHollins » Sat May 14, 2016 12:37 am
hmmm ... no luck getting this code working ... as yet. :|
Re: File Handling
Postby Walter Sommerfeld » Sat May 14, 2016 11:40 am
Here u go...
Have Phun ;-)
Warning: Dest will be overwritten and path must exist...
...I think U need Admin rights because of ProgFiles path 4 this test schematic:
copy file fom DWB in ruby (sun mod).png (288.42 KiB) Viewed 18372 times
copy file fom DWB in ruby (sun mod).fsm
(1.31 KiB) Downloaded 818 times
Walter Sommerfeld
Users browsing this forum: No registered users and 82 guests
