Dual Column selection
Postby RJHollins » Mon May 16, 2016 11:49 pm
Hi GANG,
Planning a different type of FS project [at least different than what I'm use to.
One of the design features I'm considering ... but not really sure of exact, technical description is basically:
Two TEXT boxes [side by side].
The LEFT side contains all the 'elements' available. These can be selected individually using the same 'Windows' protocols like [CNTRL]-Mouse to select at random, and [SHIFT]-mouse to select in groups.
Once selected, using an ARROW button, the selected elements can be MOVED to the RIGHT side Panel.
Just the same, an element[s] on the RIGHT side can be MOVED back to the LEFT [available] side.
Any of this make sense :lol:
More importantly ... has any body already created this 'wheel' ??? if so ... wanna share :shock:
In humble gratitude ... thanks for reading ...
Re: Dual Column selection
Postby Tronic » Tue May 17, 2016 6:31 pm
I did something quickly for you,
if there are bugs let me know.
For RJHollins user case
:arrow: viewtopic.php?f=3&t=3928&p=24368#p24368
Tronic
Postby RJHollins » Tue May 17, 2016 6:43 pm
Found it !!
8-) 8-) 8-)
Users browsing this forum: No registered users and 76 guests
