Postby tiffy » Wed Jun 08, 2016 5:52 pm
TRIGGER SWITCH (RUBY)
Description inside module.
Trigger Switch (Ruby).fsm
(517 Bytes) Downloaded 1194 times
tiffy
Postby tiffy » Thu Jun 09, 2016 5:24 pm
MOUSE CURSOR WITH TRANSPARENT COLOR FOCUS:
Mouse Cursor with Transparent Color Focus.fsm
(1.24 KiB) Downloaded 1214 times
tiffy
Postby RJHollins » Thu Jun 09, 2016 6:32 pm
Cool stuff, TIFFY :D
Thanks for posting !
Postby tiffy » Mon Jun 13, 2016 6:39 pm
1 Hz TICKER:
A simple general purpose Ticker/Flasher constructed with Primitives.
However, if you need accurate timing rather use a Ruby Ticker instead.
1 Hz Ticker.fsm
(2.65 KiB) Downloaded 1163 times
tiffy
Postby BobF » Mon Jun 13, 2016 7:36 pm
Hi Tiffy,
Great stuff, keep them coming. I am sure these will all be put to some good use in the near future.
Later then, BobF.....
BobF
Postby tiffy » Tue Jun 14, 2016 9:55 pm
GRAPHIC COUNT DOWN TIMER (Ruby):
The ticker & graphics make use of Ruby but other control circuitry make use of green.
Description inside schematic.
Note: The timer can only make use of "Full Seconds" and not "fractions of a Second" entered into the text Box. It will 'ignore' any fractions of a Second given to it. This is only a Display Example.
Graphic Count Down Timer (Ruby) v3.fsm
(35.92 KiB) Downloaded 1194 times
tiffy
Postby RJHollins » Tue Jun 14, 2016 10:21 pm
getting a RUBY error, undefine method, 'scheduleMethod'
Postby tiffy » Wed Jun 15, 2016 6:18 am
RJHollins wrote:getting a RUBY error, undefine method, 'scheduleMethod'
Sad to hear, but with flowstone v3.0.7 it shows no error on my side. But I will have a look at the code, it is possible that there is some undefined method in there somewhere. Strange that the error does not show up in v3.0.7. which makes it difficult to detect if an error exist or not.
Does the error shows up in the "ticker" Ruby module (which is not my work) or in my "Graphic" Ruby module?
Thanks for your feedback.
tiffy
Postby tulamide » Wed Jun 15, 2016 6:55 am
scheduleMethod was introduced with 3.0.6, so you've done nothing wrong, Tiffy, just RJs Flowstone 3.0.4 is simply too old.
I propose to clarify which version of Flowstone is needed as a minimum to use Ruby-modules. One could consult the changes list of the versions, maybe.
Postby RJHollins » Wed Jun 15, 2016 5:45 pm
Thanks for checking TIFFY. It was in your module.
It would be difficult to know what version everyone is using ... yeah, I'm still with 3.04. Most times this has not be issue ... but every once in a while. :roll:
