Crazy question
Crazy question
Postby BobF » Sat Jul 30, 2016 6:38 pm
Hello gang,
If I wanted to control the gain of a amp (normal 0 to 1) via midi note data, how would I go about it. For example say you played middle C, make that put out a value of .5 to the amp and so on. This is just an example, NOT saying I would always want middle C to put out .5, but would rally like it to be adjustable across the keyboard. Hope this makes sense.
That's it! Thanks, BobF.....
BobF
Re: Crazy question
Postby RJHollins » Sat Jul 30, 2016 7:07 pm
Maybe look at the VCA primitive.
Re: Crazy question
Postby BobF » Sat Jul 30, 2016 8:00 pm
Hi RJ,
Thanks for the feedback, but I have tried that and it does NOT work.
Do you have a working example?
Later then, BobF.....
BobF
Re: Crazy question
Postby RJHollins » Sat Jul 30, 2016 8:47 pm
This is one idea I used for a project.
VCA control.jpg (61.9 KiB) Viewed 25749 times
Here's the example schematic:
VCA control.fsm
(121.55 KiB) Downloaded 1066 times
Re: Crazy question
Postby BobF » Sat Jul 30, 2016 8:56 pm
Hi again RJHOLLINS,
Thank is exactly what I used. Can you show me where and how the midi data controls this!
Thanks once again, BobF.....
BobF
Re: Crazy question
Postby RJHollins » Sun Jul 31, 2016 2:34 am
Hi BobF,
I'm not exactly sure what you need to do ... my guess ...
You want to use MIDI data to set an audio volume. If so ...
Audio data into the knob [if you want to use it], is scaled from 0-1
MIDI data is 0-127
There are some 'scaling' modules that will correlate one range of values to a different range. That is, values from 0-127 will be re-scaled into 0-1 values.
These scalers might be on the FS forum. I know we found them on the old SM forum.
If this is what you want to do ... If you need the 'scalers', let me know and I can post here for you.
This assumes I understand your question :roll:
Re: Crazy question
Postby adamszabo » Sun Jul 31, 2016 12:36 pm
I think Bob wants what is called Keyboard Tracking or Key Tracking or Key Follower. Have a search with those keywords and you will find lots of info :D
adamszabo
Re: Crazy question
Postby BobF » Sun Jul 31, 2016 5:14 pm
Hi once again RJHOLLINS,
Yes you are correct, scaling is what I believe I need. If you have something, sure I would like to see it.
Really appreciate your help here.
Hi adamszabo,
THANKS ALSO, I will do a search.
BobF
Re: Crazy question
Postby RJHollins » Sun Jul 31, 2016 5:43 pm
Hi BoBF
Here are a few 'scaling' modules from my toolbox. These are User contributions that I collected.
8-)
Scaling [various].fsm
(24.27 KiB) Downloaded 1044 times
Re: Crazy question
Postby BobF » Mon Aug 01, 2016 12:44 pm
Thanks RJHOLLINS,
I will look at these soon.
Tare care, BobF.....
BobF
