FlowStone 3.0.9 Beta2
Re: FlowStone 3.0.9 Beta2
Postby djbrynte » Thu Jun 02, 2016 11:19 pm
are the wave read bugg fixed? the one when you use FM?
Also flowstone crashes when i open a project.
djbrynte
Postby Nubeat7 » Mon Jun 13, 2016 10:35 pm
any news about when the final version will be available, i'm sitting on needles to finally update from 3.06 to take profit from all the new stuff since then :)
Postby Rocko » Thu Jul 21, 2016 9:24 am
This seems to me as a bug as well.
Cascading two 'code' modules and connecting the output to 'ASIO out' provides wrong result.
It seems that one value overwrites the other.
Please see attached file. I had marked 'wrong' and 'right' values acordingly.
This is what I see on my screen:
http://pasteboard.co/e4RMgco5X.jpg
Why is 'wrong' set to 0.5, while it should be 1 (only when connected to ASIOoutput) ?
Bug_1.fsm
(1.11 KiB) Downloaded 1987 times
Rocko
Postby martinvicanek » Wed Aug 17, 2016 8:22 am
the Mono to Frame prim seems to have an issue. I am experiencing random crashes with the schematic on page 223 of the manual (see below) when I switch off stream processing.
It happens with any of Direct Sound, ASIO4ALL or the ASIO driver of my adapter.
It happens with FS 3.0.8.1, FS 3.0.9 Beta, and FS 3.0.9 Beta2.
Anything you can do about it? Many thanks.
Postby MyCo » Wed Aug 17, 2016 6:46 pm
@Rocko: You are writing to an input variable
@Martin: I'll have a look... but I guess it's one of those problems that depend on the system (As I would have noticed that before)
MyCo
Postby martinvicanek » Wed Aug 17, 2016 8:48 pm
Thanks MyCo.
My system is Win 7 Home Premium SP1, 64 Bit, Athlon II X4 640 if that is of any help at all.
Postby MyCo » Thu Aug 18, 2016 8:17 pm
I can reproduce the problem... it looks like a deadlock of something, quite hard to figure out what's actually causing this
MyCo
Postby Duckett » Tue Sep 13, 2016 2:25 pm
New user here (Win 7 x64), just checking in to say that 3.0.9 Beta2 crashes more often than not... it doesn't seem to be any particular action that crashes it, but I can get an average of 5 min. before it dies.
Duckett
Postby lalalandsynth » Mon Oct 03, 2016 4:47 pm
Always crashes for me when i close properties for a knob.
Lots of crashes when messing with knobs.
lalalandsynth
Postby Nubeat7 » Tue Oct 11, 2016 7:23 am
what happened with the beta?
is it still in development, or did the devs quit?
