Bootsy's fast RMS ?
Bootsy's fast RMS ?
Postby lalalandsynth » Sun Oct 02, 2016 4:00 am
I need to derive a trigger from an audio stream ,preferably a detector with some kind of sensitivity setting and low ripple, searching the forums it seems that Bootsy's fast RMS might do the trick but i cannot find it anywhere , anyone have this thing lying around somewhere ?
Just bought Flowstone today , having fun :)
Thanks
lalalandsynth
Re: Bootsy's fast RMS ?
Postby martinvicanek » Sun Oct 02, 2016 8:15 pm
Hi lalalandsynth and welcome to the Forum!
Bootsy's work is probably burried in the old Synthmaker forum. I can offer you my own onset detector which I use to trigger a synth with live audio (e.g. guitar).
An onset is detected if two criteria are met:
1. signal is a certain factor above delayed signal
2. signal is above noise floor
In general these criteria will be met for a certain period of time. At the end of that period, an onset event is reported along with a measure of the strength of the event (velocity).
The schematic includes optimized ASM code however I usually save a (more readable) code version along with the ASM.
Have fun!
OnsetDetector.fsm
(49.42 KiB) Downloaded 900 times
Postby BobF » Sun Oct 02, 2016 10:46 pm
Fast RMS.fsm
(12.91 KiB) Downloaded 884 times
Hello lalalandsynth,
If for some strange reason Martin's "OnsetDetector" does not work.
I found this one some time ago. Do NOT know who's it is though.
Good luck and welcome to the forum, BobF
BobF
Postby lalalandsynth » Mon Oct 03, 2016 12:16 am
Thanks guys , will try these out :D
lalalandsynth
Postby lalalandsynth » Thu Oct 06, 2016 8:43 pm
How can I turn this onset trigger into a gate for an an envelope ?
lalalandsynth
Users browsing this forum: Google [Bot] and 82 guests
