drum pads
drum pads
got a couple of queries regarding drum pads. in the drum pad test A fsm I would like to know how to make the folder selector work instead of the load button which is connected at the moment. when I link it up it keeps reopening the selected folder over and over without loading a new wave file. also in the machine spogged 2 fsm I'm trying to get the detuner/transposer to work but it just causes distortion. wondered if anyone could figure these issues out.
- machine -spogged 2.fsm
- folder select problem
- (115.16 KiB) Downloaded 887 times
- drum pad test A.fsm
- detune problem
- (99.49 KiB) Downloaded 841 times
scanz - Posts: 12
Re: drum pads
"machine -spogged 2.fsm"- The problem was the using of the pitch output from the midi to poly instead of using frequency output+turning on the boolean switch inside the counter module which connects the the manipulated frequency to the "PreciseCounter"module.
About the drum pad test A: You should combine a preset manager in this schematic or it would never save the last settings and keep opening the same folder every time.
- (machine -spogged 2_fixed).fsm
- (117.86 KiB) Downloaded 912 times
- (drum pad test A fixed).fsm
- (104.38 KiB) Downloaded 866 times
kortezzzz - Posts: 763
Users browsing this forum: No registered users and 52 guests
