Ruby question-delete files by their suffix; possible?
Postby kortezzzz » Fri Oct 28, 2016 8:30 pm
I have this code which is based tulamide's suggestion.
def event i
   if i == "do_it"
      File.delete(@path, File.dirname(@path))
This ruby code deletes a given file from the H.D. if you feed it's string input with the full file's name+location
(for instance: "C:\Users\kortezzzz\Pictures\bla bla.png") and push the trigger input. The problem is that it won't delete as many files as you need (based on their suffix) if you feed it's string input with "*.something" method like the windows "CMD" command line does (for instance: "C:\Users\kortezzzz\Pictures\*.png"). Is there any way to force ruby do it?
kortezzzz
Re: Ruby question-delete files by their suffix; possible?
Postby KG_is_back » Fri Oct 28, 2016 9:00 pm
Yes, it can be done, actually very easily.
def event(i,v,t)
if i == "do_it"
paths=Dir.glob(@path) #makes an array of all files which match shell-styled pattern (for example "C:/*.doc")
paths.each{|path| #iterates through the array and deletes files one by one
File.delete(path, File.dirname(path))
EDIT: I messed up the parentheses... fixed now
KG_is_back
Postby kortezzzz » Fri Oct 28, 2016 9:32 pm
Thanks for the super fast reply, KG :)
For some reason, your code gives an error message on line no. 6
Seems like I'm doing something wrong. Uploaded my little schematic here for testing.
Thanks a lot!
(ruby- delete by preffix).fsm
(588 Bytes) Downloaded 1418 times
kortezzzz
Postby kortezzzz » Sat Oct 29, 2016 9:18 am
Sorry KG, but it's not working for me even after your edit. Can you please take a look at the schematic? Perhaps FS ruby doesn't support that feature?
kortezzzz
Postby kortezzzz » Sat Oct 29, 2016 11:02 am
Found other cool, easy and green way to it by calling "CMD" feature (using the "Exec" primitive). This combination can do so much more and it's easy to use as well.
Thanks anyway, KG :D
(delete any file_green).fsm
(1.7 KiB) Downloaded 1447 times
kortezzzz
Postby rewiredrecords » Wed May 19, 2021 10:45 pm
kortezzzz wrote:Found other cool, easy and green way to it by calling "CMD" feature (using the "Exec" primitive). This combination can do so much more and it's easy to use as well.
Excellent! Thanks mate. Just what I needed :D
rewiredrecords
