Mouse Scroll commands
Is there any way for me to control 'mouse scroll' button via flowstone (Ruby? Green?) ?
Thanks,
Rocko
Thanks,
Rocko
- Rocko
Re: Mouse Scroll commands
Yes you can do it in the 3.0.9 beta
- adamszabo
For 3.0.9 Beta2 I see a 'mouse wheel' module in green. Is that what you are referring to or is there a way to implement it in a RUBY code?
Thanks,
Rocko
Thanks,
Rocko
- Rocko
Ruby using:
def mouseWheel x,y,w
# do something with x,y,w
- Tronic
This doesn't seem to work correctly. I'm simply trying to output the x,y,w readings to float (see simple schematic) and I receive wrong data.
Sometimes the 'w' data get updated (1 or -1) and sometimes it doesn't.
Am I doing something wrong or is there still a bug with 3.0.9 BETA ?
def isInMousePoint x,y
true
output 0,x
output 1,y
output 2,w
- mouseWheel_test.fsm
- (1.01 KiB) Downloaded 984 times
- Rocko
Has anyone succeeded to work this out ?
- Rocko
Hi Rocko,
Yes...
You can find an example here...
http://www.dsprobotics.com/support/viewtopic.php?f=3&t=3860&start=0&hilit=mouse+wheel
I then used your example and got it working (3.0.9 Beta 2)
Aron
Yes...
Aron
aronb - Posts: 154
Thanks.
So this function will not be functional with v3.08.1, correct?
Thanks.
- Rocko
Users browsing this forum: Google [Bot] and 69 guests
