Gated
Gated
Postby BobF » Tue Dec 13, 2016 5:20 am
BobsGatedS&H_VCA.fsm
(433.75 KiB) Downloaded 1080 times
Hello gang,
Here are a couple of very easy circuits I through together. I made a couple of these several years ago for a homemade hardware synthesizer I made, and thought they might be interesting to do in Flowstone. One is a gated VCA and the other is a gated sample and hold. You can select between 6 different types of gating, xor, xnor, or, nor, and, & nand. These are logic gates, so if you are not familiar with there functions, just Google them. The -1 to 1 knob kind of acts as a trigger point in some settings. The best thing to do is just play with them, you will see what they can do. Some use ideas are to just name two would be, wave-shaping and modulation. *** Note NOT all setting will have a useful function!
Please post, any ideas you come up with! Uses, mods, or what ever.
Have fun then, BobF.....
BobF
Re: Gated
Postby Spogg » Fri Dec 16, 2016 10:43 am
Hey Bob!
I really like this. I had a quick play around and got some great sounds and, importantly, some wide-ranging variations with the +/- 1 knob and detuning.
Have you thought about making a morphing-style synth with this and/or one with LFO/ADSR modulation? I think you should! I would expect some aliasing due to the sample level switching not always aligning exactly the same for every period but it might be worth experimenting.
Thanks for sharing.
Re: Gated
Postby BobF » Sat Dec 17, 2016 3:35 pm
Thanks Spogg,
Yes, I may look into this in the new year!
Cheers, BobF......
BobF
