How to start your App. on a second monitor
Postby frank-riedel » Thu Dec 20, 2012 2:32 pm
Hi
Is there some way to control that the program you compiled should startup on a specific monitor
say 2 or 3 on windows ???
I know i can move the icon to the monitor and start it from there.... but if i want it to startup
with windows boot on a my second monitor.... any way to do that ??
/Frank
frank-riedel
Re: How to start your App. on a second monitor
Postby Nubeat7 » Thu Dec 20, 2012 7:43 pm
i think windows remember where it was open the last time, so when u open it make "small window" put it on the monitor youwant to have it and then make fullsize, the next time windows should remember the screen... it works like this with cubase, live... on my system..
Postby frank-riedel » Thu Dec 20, 2012 9:10 pm
ALSO when you created your app. with fullscreen enabled ??
/Frank
frank-riedel
Postby Nubeat7 » Fri Dec 21, 2012 1:33 pm
i didn`t try it with own apps because i`m onyl doing vsts, just can tell you that it works with other programs... did you try if windows remember?
Postby frank-riedel » Sat Dec 22, 2012 12:13 pm
Hi and thanks for reply
No, it do not rember in full screen
/Frank
frank-riedel
Postby Asbjørn » Tue Dec 25, 2012 2:37 am
I had the same issue before Flowstone supported high resolutions, I had to split my application into two seperate applications, one for each monitor, but the problem was Flowstone would only open on monitor 1, no matter what. No solution.
Asbjørn
Postby frank-riedel » Tue Dec 25, 2012 11:53 am
So the only solution is to start the app. on the monitor where you want it to run !!!!!
frank-riedel
