Ruby: require 'randomsecure' - Problem
When I run the Ruby “require 'randomsecure' “ instruction in the Flowstone Ruby interpreter it does what it is supposed to do, but when I export the code in the attached schematic as an *.exe file, then the *.exe file does not function at all. It appears then that the “ require ‘randomsecure’ “ instruction does not find the “randomsecure.rb” file only when the schematic is exported as an *.exe, but why? The *.fsm file and the *.exe exported file as well as the “randomsecure.rb” file (also attached for convenience only) all stays in the exact same folders, nothing changed. The code in the schematic is part of another larger schematic I am working on.
Unique Random Code Generator.rar- (4.34 KiB) Downloaded 881 times
tiffy - Posts: 400
Re: Ruby: require 'randomsecure' - Problem
I quote the user guide, chapter 8, section "Ruby Limitations", page 232:
So, in order to use them in a VST, you'd need to place the code from SecureRandom (and all dependencies that are outsourced) in RubyEdits and take care that they are initialized in the correct order. They are then included in the exported dll and should work as any code you enter in RubyEdits.
Of course, that only works with extensions or Gems that are written in Ruby. Precompiled ones won't.
Currently VST plugins generated by FlowStone cannot make use of Ruby extensions or Gems.
tulamide wrote:I quote the user guide, chapter 8, section "Ruby Limitations", page 232:Currently VST plugins generated by FlowStone cannot make use of Ruby extensions or Gems.
Thanks again tulamide, I surely missed this one in the userguide.
tiffy - Posts: 400
Users browsing this forum: Google [Bot] and 32 guests
