SFZVibeFX Soundfont Sampler 03/11/25
Postby pwesynthmaker » Tue Mar 04, 2025 1:02 pm
Download Updated: 03/11/25
SFZVibeFX
SFZVibeFX Project Files Download Link:
https://www.inventorefx.com/_ifxfstone/sfzvibefx.zip
View Large Image:
https://www.inventorefx.com/_ifxfstone/sfzvibefx_lg.jpg
SFZ Soundfont Sampler with:
Octave/Semitone Transposer
BPM (Beats per Minute 60-240 Range Slider Sample Rate Synced)
Pitch Bend Control (Depth, OFF/ON Switch)
Vibrato (Variable Range/Multi-Waveform LFO w/BPM Sync, OFF/ON Switch)
ADSR Envelope Generator
VCA/VCF Filter
Stereo Out Pan (Left<-->Right)
SFZ Volume Level
Preset Manager Controllable SFZ Loader
Custom Designed Preset Manager with:
Preset LOCK/UNLOCK to protect Presets from accidental overwrite
Multiple Preset Types Management (SFZ Soundfonts & Mod Parameters)
Adjustable Presets Quantity 1-128 ('Click On' Small White Box, Enter Value)
CAUTION! LESS ANY THAN PREVIOUS SET VALUE ('DEFAULT' 32)
WILL DELETE THOSE STORED PRESETS. USE INCLUDED BACKUP TO RESTORE.
SAVE EACH/ALL PRESETS TO TEXT '*PRESETNAME.TXT' FILE(S) FOR SAFETY.
Standalone Executable has Keyboard with Key Sustain LOCK,
Octave Selectable Range (Slide Mouse Pointer/TouchPad Up/Down on Screen)
(Keyboard N/A with VSTi Plugin for DAW Efficiency).
CAUTION! USE ONLY ONE OF EACH VSTI PLUGINS:
sfzvibefx (64).dll
sfzvibefx (64).vst3
sfzvibefx.dll
sfzvibefx.vst3
'Custom Designed' SFZs
REPLACE PREVIOUS DOWNLOAD DO NOT OVERWRITE
Download Link:
https://www.inventorefx.com/_ifxfstone/pwesfzs.zip
HINT:
The included EFXVST\pwesfzs Subfolder is where the SFZs are stored.
Copy the EFXVST Folder directly to OS (Operating System) C:\ Drive.
This will allow the Preset Manager and SFZ Loader to
'Automatically' assign/load the included SFZs into the SFZVibeFX [sfzvibefx] VSTi Plugin of choice.
Otherwise, it will be necessary to manually load each SFZ if they are located elsewhere.
Last edited by pwesynthmaker on Sun Feb 08, 2026 1:59 pm, edited 10 times in total.
Inventor eFX Technology
pwesynthmaker
Re: SFZVibeFX Soundfont Sampler 03/04/25
Postby martinvicanek » Wed Mar 05, 2025 10:51 pm
Thank you, pwesynthmaker, for the sfz sample player. Flowstone’s sfz parser prim has not been used very much, at least not that I am aware. I use sfz based instruments a lot in my recordings, however with a non-FS sample player. It seems worthwhile to explore FS’ capabilities for sfz processing because we can have much more control compared to using a ready-made sample player.
I do use FS for preprocessing my samples which I employ in my instruments, though. But there is more potential for FS to help creating an sfz instrument. Certainly something to think more about!
Re: SFZVibeFX Soundfont Sampler 03/10/25
Postby pwesynthmaker » Mon Mar 10, 2025 9:48 am
You are graciously welcome MV!
Now that I am aware you are a 'MIDI Fan'
here is one of my latest and probably most favored of all time classics:
Cliffs Of Dover by Eric Johnson
Download Link:
https://www.inventorefx.com/_ifxfstone/ ... r_mids.zip
CONTENTS:
cliffsofdover_orig.mid (MPE Version 3 Tracks)
INDIVIDUAL TRACKS EA. W/INDIVIDUAL SAMPLER:
cliffsofdover_gtr.mid (FlowStone SFZVibeFX Compatible I use Preset 9)
cliffsofdover_bass.mid (FlowStone SFZVibeFX Compatible I use Preset 10)
cliffsofdover_perc.mid (FlowStone SFZVibeFX Compatible I use Preset 11)
cliffsofdover.mid (MPE Version of Above 3 Tracks)
P.S. Also be sure to 'add/scan' for the new [sfzvibefx] VSTi
and enable MPE (MIDI Polyphonic Expression) in your DAW
and turn on the 'PBend' (75-100%) in Guitar and Bass SFZVibeFX Vsti's.
Last edited by pwesynthmaker on Sun Feb 08, 2026 2:01 pm, edited 2 times in total.
pwesynthmaker
Re: SFZVibeFX Soundfont Sampler 03/10/25 PST
Postby martinvicanek » Mon Mar 10, 2025 5:41 pm
Thanks, Paul! I did finally manage to play your MIDI files, however, with another SFZ player, so I am not sure if it sounds the way it is supposed to. The reason why I failed with your SFZ player is because I don't know where it looks for the sfz and sample files when it is instructed to load a specific preset. Hence there was no sound at all (but no error message either). Why don't you just share an mp3?
Re: SFZVibeFX Soundfont Sampler 03/11/25
Postby pwesynthmaker » Tue Mar 11, 2025 12:53 am
I RECENTLY UPDATED THIS PROJECT SO I WOULD RECOMMEND A REPLACEMENT (NOT OVERWRITE) DOWNLOAD.
THE DOWNLOAD LINKS IN THE FIRST POST ARE UPDATED TOO.
Cliffs Of Dover MIDI Exported as
MP3 Download Link:
https://www.inventorefx.com/_ifxfstone/ ... er_mp3.zip
This Version is Produced with FlowStone SFZVibeFX VSTi DAW Plugin.
Sound Effects added by FlowStone eFXatron VST DAW Plugin
HINT:
For instance, if you download to the 'Downloads' Folder simply press the SFZ 'Load' button and in the
Explorer window that appears go to that directory.
EXAMPLE:
%UserProfile%\Downloads\sfzvIbefx\EFXVST\pwesfzs\[SFZFOLDER\FILENAME.SFZ]
In most DAWs new loaded SFZs and Plugin Settings will be saved with the DAW Program File for future access.
The FlowStone Preset Manager I built also embeds saved Preset Mod Control Settings and SFZ Location/Directory.
If you open the 'presetsfztxt' Folder and open any Preset Text File at the bottom on Line 29
is the 'String Code' identifying the SFZ and its location.
EXAMPLE:
String C:\EFXVST\pwesfzs\pwemidsfzs\64 Synth Brass 2 C#4.sfz
As previously mentioned above, placing the EFXVST Folder on C:\ Drive is much less confusing and less time consuming.
I even keep all my actual VST/VSTi Plugins there too!
Faster and easier than having to Copy same to the VST Folders in:
C:\Program Files (x86)\Common Files
or
C:\Program Files\Common Files
I hope everyone can benefit from these instructions.
This little bit of info is so hard to obtain without at least some guidance.
pwesynthmaker
