Multiplex & audio routing.
I know the quirks of the multiplex in terms of routing values but I cannot remember if its supposed to work properly for routing audio signals , it is not working properly for me at least.
What to do when you need to route one Audio source to mutiple places and cannot use the Selector ?
Never really understood why there is not a selector with one input and multiple outputs .
I think there might be something else wrong here.
I have two signals going into a selector and it plays NR1 even though I switch in NR2 ?
ok, restarted FS , and it seems to work now , super weird !
lalalandsynth - Posts: 600
Re: Multiplex & audio routing.
sure you can use the multiplexer for audiorouting.
using the multiplexer forces a recompile everytime you change the target, this can result in audiocrackles.
to avoid this you can write it in dsp code like this.
multiplexer.fsm- (1.16 KiB) Downloaded 880 times
Nubeat7 - Posts: 1347
Nubeat7 wrote:sure you can use the multiplexer for audiorouting.
Very cool NuBeat ...
I know DSP less than RUBY ... saying that ... how to expand this Multiplex to handle Stereo pairs ?
Nubeat7 wrote:just use packed mono4 ins and outs...
Thank-you Sir ... I'll give that a try.
OK ... got it working with the PACK in/outs.
Thanks again NuBeat
Thanks again NuBeat
Thanks , this works great !
